Front Caliper Bracket Bolts Too Long? - Wrong Rotor
jimmycakes401
Post by jimmycakes401 »
Just received my rotors from IAP. The back went great, the front however is not going well. My bracket bolts are long enough to touch my rotor. Which is not good. Did they send me the wrong rotor? Has anyone else had this issue? I can't find any info on it through the 'search' function.
bobplyler
Patron 2022
Patron 2022
Re: Front Caliper Bracket Bolts Too Long? - Wrong Rotor
Post by bobplyler »
The front and back rotors are the same. Maybe a washer left out?
1979 Fiat Spider (since new)
1999 Honda Shadow VLX 600
jimmycakes401
Good news. After hours of rage, lol, I realized that I mixed in sone extra bolts from another rear end I have. Figured they were the same. But closer inspection revealed a tiny difference in length.
manoa matt
Post by manoa matt »
The long bolts are for the rear axle and the shorter bolts are for the front. On the front the bolt passes through a thin stamped steel caliper carrier bracket. On the rear the bolt passes through a thick metal flange on the axle.
