hazard switch
lorne
hazard switch
Post by lorne »
Can someone send me a pic of the hazard switch on my 74 124 spider,removed wires now i don't know where they go the switch has 6 connectors thanks
tartan18
Your car is a: 1975 Fiat 124 Spider
Re: hazard switch
Post by tartan18 »
With my 1975 I found that nearly every lighting circuit in my car ran through through the hazard warning light/assembly. It took me a long time to finally get a wiring diagram for my car so my strong suggestion is to get a wiring diagram for yours ASAP. If it is too small then take it to your local Staples or other office copier/printer and get a large copy made so you can trace each wire from the beginning to the end. As I recall model year 1974 wiring diagrams are tough to find -- hopefully another forum member has this for you. Good luck.
Jim MacKenzie
1975 Fiat Spider
lorne
Re: hazard switch
Post by lorne »
Found a harness with a switch on it so i just replaced the harness thanks for the reply
