I just finished a timing belt replacement (82 FI ) and all went well. However the directional and the high beams don't work. I checked the fuses and wires and they seam fine. Junior has sat for a week but that should be of no issue. It is probably something stupid but I can't put my finger in it.
Any suggestions will be greatly appreciated.
Thanks.
Joe Pescatore
Directional lights and high beams.
- Your car is a: 1982 Pininfarina
Re: Directional lights and high beams.
Have you rechecked all the grounds on the ground spiders located on the inside of the fenders on both sides of the radiator? This is what I would check first.
Good Luck
Good Luck
Yes I checked the grounds, tomorrow I will take them off and clean them. The High beams work but the directional lights do not. Also the indicator lights for both on the spedo don't light. I wonder if it might an issue with the wiring on the steering column, both arms are located on the left side.
Joe
Joe
- TulsaSpider
Might try checking the fuses. They can become loose. If so carefully close the ends up a little. Sometimes I have to tap mine with my fingers
All is well with the directional lights. I found a posting regarding the connection between the Flashers and the Directional Lights. I pulled the fuse on the Flashers which also controls the clock when I store Junior for long periods of time to conserve the battery and didn't replace it this spring. I must have pushed the Hazard button in before I replaced the timing belt. With the button pushed in the Directional Lights will not work. Once the Forum came to my rescue.
Thanks to all.
Joe Pescatore
Thanks to all.
Joe Pescatore
if the flasher work.. does the blinkers run off of that same flasher? or is there some other component
69 spider
69 spider
Jim
East Grand Forks MN
1969 124 AS Spider
2017 Abrath
2018 Alfa Romeo 4c Spider
East Grand Forks MN
1969 124 AS Spider
2017 Abrath
May I suggest, that if you park your spider up over winter, you do what I did to stop having to play with fuses.
Cost me about $4.50 to buy an isolater terminal. Just pull earth lead off the battery, fit new terminal to battery post, then attach earth lead to end post on the new terminal. It has a plastic thumbwheel to make & break contact and isolate battery in a few seconds. Also means you can put charger on the battery insitu without affecting car circuits.
