Carrier bearing replacement
cfd2bc
Post by cfd2bc »
Hello all. I am trying to replace the carrier bearing. To get the bearing and assembly off, do I remove the 27 mm nut on the yoke (where the u joint is) and press the spline out of the yoke? That looks to be the only way to do it. Hopefully this makes sense.
Thanks, Jeff
htchevyii
Patron 2022
Patron 2022
Re: Carrier bearing replacement
Post by htchevyii »
Funny, I just changed mine today. After removing the u joint, I used a punch to bend out the staking on the 27mm nut and removed it. Then I used a 2 jaw puller to pull off the old bearing. The rubber support was all trashed, so the outer part kind of ripped off and I attached the puller to the bearing and it came right off.
Trey
