Special TC Engine
Special
Your car is a: 1974 Special TC
Re: Special TC Engine
Post by Special »
htchevyii wrote:Almost a shame to hide that in a car, it belongs in a museum!
Thanx.
Special
Post by Special »
dom wrote:How do you plan to lift the engine for installation? With the intake manifold installed you can't use a harness. I want to install manifold and carbs while the engine is out but I cant think of a way, maybe use head bolts.
It takes only 5 minutes to remove the whole intake with carbs..
I will definitely do it to prevent any damage.
Special
Post by Special »
hayesbd wrote:Wow!
That is one amazing engine! Can you rebuild mine? Please!?
Brian
Sure , just send it over.
It will be done at no time.
Special
Post by Special »
If somebody still interested what happened to this engine , I'll answer - Nothing !
It is still sitting in the same spot.
Just because I could not put it here -
So , everything was cleaned up a little -
And after the paint dried out and I started to put everything back together.
The hydraulics is all fitted and connected . Me and my son , we bled the brakes - all 8 bleeders , nothing leaks and the pedal is nice and stiff.
Looks like everything is ready for the engine implant.
Cleaned and painted sub-frame as well
And I just got these today
westy64
Post by westy64 »
fiat218 wrote:So I got a 79 with dual carbs, I should prolly need that to adjust the fuel so it 3psi
why not directly use a pump that would push only 3psi ?
some are good, inexpensive, silent and easily sourceable (pierburg is pretty much used in the aircoold VWs vho run dual carbs too).
but there are others, of course.
Redline
Your car is a: formerly a 1971 Fiat 124 BC Coupe
Post by Redline »
That engine bay is beautiful and I really like your attention to detail. Do you have a spray booth, or is this all in your own garage/driveway? It looks fantastic.
It warms my heart that someone puts so much effort into a 124 sedan.
http://www.124bc.com
narfire
Post by narfire »
I agree, your attention to detail is terrific. Impressed and jealous as well.
Going to be a real source of pride.
Well done
Chris
Special
Post by Special »
Thanx guys !
Unfortunately I don't do body work myself .
So I took it to the body shop.
All welding , prepping , priming and painting was done over there.
Under my supervision , of course . :D
And yes - details is everything.
I was taught that way - do it right , or don't do it at all.
To be continued .
focodave
Post by focodave »
Special,
Your's is simply one of the nicest looking 124 sedans out there.
Bravo!
Dave
1970 MGB GT (my other hobby)
Post by RRoller123 »
Man that is nice! Bravo!
vandor
Post by vandor »
Dang, amazing looking engine bay.
Just a quick note, I hope you won't be using that super-short runner header, it is very restrictive.
giuliot60
Your car is a: 81 Fiat Turbo removed Spider
Post by giuliot60 »
It looks great! And looks like my first car mid 70's 128 sedan, even the color. It is a 128 correct?
Special wrote:If somebody still interested what happened to this engine , I'll answer - Nothing !
Giulio/Charlotte
vandor
Post by vandor »
This is a 124 sedan. The 128 was front wheel drive.
giuliot60
Post by giuliot60 »
vandor wrote:This is a 124 sedan. The 128 was front wheel drive.
Duh. That makes sense. :) But the nose looks just a 128. Maybe the color threw me off.
Thanks C.
GT.
Giulio/Charlotte
rebar1111
Patron 2019
Patron 2019
Your car is a: 1979 124Spider
Post by rebar1111 »
Stock 79 TC carb linkage shortened about an inch will work the dual IDF's. Of course you will need the cams between the matched IDFs to connect to.
