zachmac wrote:If you REALLY want to get into the weeds, this link takes you to the Bosch L-Jetronic manual which goes much further than you probably ever want to go!
http://bama.ua.edu/~darren/boschindex.html
Recommended Tools, Spare Parts, Books?
- Snoopy
- Your car is a: 1980 CS0 2000 f.i. US [Build 1979]
Re: Recommended Tools, Spare Parts, Books?
CS0 2000 f.i. 79, Abarth 500C 595 2013, Ford C-MAX 1.0 Ecoboost 2015
- wachuko
- Contact:
Another site with the same pdf is listed in my first post: http://foxed.ca/rx7manual/manuals/BOSCH ... Manual.pdfSnoopy wrote:zachmac wrote:If you REALLY want to get into the weeds, this link takes you to the Bosch L-Jetronic manual which goes much further than you probably ever want to go!
I will add that second site as well.
Drive Safe!
Wachuko
1967 912 Progress Thread
2012 BMW X5 xDrive35d
2015 FIAT Abarth
Wachuko
2015 FIAT Abarth
- wachuko
- Contact:
Added a MIG welder to the list and the great site recommended by Michael (seabeelt) - http://www.mig-welding.co.uk/mig.htm
Drive Safe!
Wachuko
2015 FIAT Abarth
Wachuko
2015 FIAT Abarth
- azruss
only thing not discussed is a tool for removal and install of e-brake wedge in the rear caliper. I built my own. many have developed technique to not require anything special. never got those to work.
also, a roll of coins for holding a stretched clutch pedal spring.
a low-pro floor jack and jack stands.
I build myself a set of 12" drive up ramps. use them all the time. faster and safer than a jack and jack stands.
if your dizzy is up top, a custom dizzy wrench. I took an open end wrench the bent it into an ell.
a first class set of snap-ring (circlip) pliers
thread gage
impact driver with phillips bits
1/2" breakerbar and 3/4" pipe extention. (great for loosening crank bolt).
after all this, you will be too tired out to work on your car!
thread gage
- wachuko
- Contact:
Head stands...
Drive Safe!
Wachuko
2015 FIAT Abarth
Wachuko
2015 FIAT Abarth
- wachuko
- Contact:
Cool. I will update the list.azruss wrote:only thing not discussed is a tool for removal and install of e-brake wedge in the rear caliper. I built my own. many have developed technique to not require anything special. never got those to work.
thread gage
Drive Safe!
Wachuko
2015 FIAT Abarth
Wachuko
2015 FIAT Abarth
- wachuko
- Contact:
RoyBatty wrote:If you have seen this before, then disregard.
This little tool works too well to not have it in your box.
124JOE wrote:the rear calipers need to turn in to fit new pads
this tool works faster than others
One more for the tool box. Thank you Roy!
Drive Safe!
Wachuko
2015 FIAT Abarth
Wachuko
2015 FIAT Abarth
