I think I can do the pictures correctly from this point foward (one picture at a time). Most likely will attempt the installation of the top.
124JOE wrote:the top isnt hard to put on
even if its wrong if you put as much effort into it as you did getting the pics right
all will work out in the end
remove trim and old top then
center the top on the top bow and tighten
center the top at the rear bar mount
push the rear down and tighten
close the top
then pull the cables with vicegrips and tighten the mount
re install trim
ive done it four times
