Common oil leaks?
carpenduh
Your car is a: 1970 spider 124
Re: Common oil leaks?
Post by carpenduh »
Belt is off, I think part of the issue I had was being used to working with V8s, I was going on the assumption of TDC cylinder 1. From what I am seeing I should have been looking at number 4, correct?
Nut124 wrote:You might be able to adequately find TDC by feeling crank resistance.
Take plugs out. At TDC the crank should turn easy, by hand a few degrees, maybe +/-5 deg or so. TDC is in the middle of this easy movement.
Timing belt needs to be out for this.
On these engines, cylinders #1 and #4 are at the same point, that is, if one is at TDC then the other will be as well. So, you can use either to find TDC. #2 and #3 are 180 degrees out, so they would be at BDC when #1 and #4 are at TDC.
Nut124
Post by Nut124 »
carpenduh wrote:Belt is off, I think part of the issue I had was being used to working with V8s, I was going on the assumption of TDC cylinder 1. From what I am seeing I should have been looking at number 4, correct?
The crank does not know the difference between #1 or #4 firing. TDC1 is the same as TDC4. The head and ignition do care. The cam timing marks are indeed #4 firing. #1 in cam overlap.
Does the crank easy turning make sense, work for you?
