kevandandi - when I redid the carpet I put in drain plugs that can be accessed from under the car ... moisture holding jute is gone and with my neighbors wet vac that could suck water thru a brick (grunt grunt) and with dry colorado air I should be fine .... both passenger drain plugs let loose quite a bit of water this morning (yes I caught it) .... if ricambis kit is stainless
heading to autoparts store now for bypass hose and coolant t ... should be cruising by sunset ... thanks AFRetired ..
FocoDave has told me about a Saturday local car group/meet ... mostly british but all are welcome ... happy that I hopefully will make it this sat
