I give up! rename: I'll never give up;)
- Your car is a: 79 spider
Re: I give up!
the coil wire runs directly from pin 15 of the ignition switch to +B of the coil. Just run the new wires along side the old wire. it actually doesn't matter how you run it as long as you keep it from moving parts and heat.
- 70spider
- Your car is a: 1970 Fiat spider
Re: I give up!
Thanks, I'll give it a shot.
2002 Mazda Protege5
2013 Buddy 170i
2002 Mazda Protege5
2013 Buddy 170i
- 70spider
Re: I give up!
UPDATE: VITTORIA
Wow that was alot of work, I ran a new wire for the ignition and got him started then hand dialed the distributor in (for the moment). The new intake, carb and electronic ignition work awesome, the car is alot smoother and no back fire when down shifting now, so it is going to be nice to drive him without notifying the fire department before hand
One minor problem, when I reconected my fuel sending unit the fuel gauge desn't work anymore ( I just replaced a week before I started the engine upgrades).
Well I am going to take him in to get timed properly (I don't have a light and no clue how to use one) plus I need to see if my son's mechanic will tackle to suspension for me.
Mega THANKS everyone I couldn't have done it without you.
Pesto
Pesto
2002 Mazda Protege5
2013 Buddy 170i
2002 Mazda Protege5
2013 Buddy 170i
Re: I give up!
New motivation comes with every new day and this group came through for you. Really is an awesome bunch. I'm glad you stuck through and worked it out!
Re: I give up!
I'm so glad to hear you got your Spider going. It's a really good feeling when given the information necessary to fix it yourself. The folks on this forum seem to take great pride in helping others with their Fiats.They are a great bunch,...
Todd.
Todd.
1988 Mazda RX-7
1979 Fiat Spider 2000
1976 Camaro
1972 VW Superbeetle
1969 Ford F100
1968 Mustang coupe
1976 Camaro
1972 VW Superbeetle
1969 Ford F100
1968 Mustang coupe
Re: I give up!
That is great. You should re-name the post as I never give up
