dizzy springs
maytag
Re: dizzy springs
Post by maytag »
majicwrench wrote:Probably nothing wrong with the current springs. Centrifical force takes up that loosness the moment you start the car.
Keith
as usual, I think Keith is exactly correct.
Keith, can you help us pin-down his no-start?
I'm scratching my head wondering if he's got a choke? flooding it? I think you are better at chasing this stuff than I am, 'cuz you do it all day. :wink:
FordPrefect
Your car is a: 1977 Fiat Spider 124
Re: dizzy springs
Post by FordPrefect »
Keith
Yeah, after a more thorough cleaning, the springs are able to return everything all the way back now.
As for the no-start, I was able to get the car to fire briefly by working the accelerator cable at the carb (a lot), so I've got a carb kit on the way, and I'll check the fuel pump today if I get a chance. There is a screen back there, right? Is that in addition to a screen in the tank?
At any rate, I have a clear fuel filter which fills with gas, and gas pumps out of the hose ok when I disconnect it. Gas squirts down the carb when I pull the cable and the idle solenoid is ok. So maybe it's just not enough gas.
124JOE wrote:my dizzy has holes in the bottom
carb cleaner then lubracate
My dizzy also has holes. Are those to aid in dis-assembly or for draining cleaner/water?
124JOE
Re: dizzy springs
Post by 124JOE »
well theres two holes in my cap and two holes on the bottom of my dizzy
its so theres no condisasion build up.
FordPrefect
Re: dizzy springs
124JOE wrote:well theres two holes in my cap and two holes on the bottom of my dizzy
Makes sense.
