Heater fan squeeeeeel!
- 124ADDHE
- Your car is a: 1974 Spider Amalgamation with C40 Solex
Re: Heater fan squeeeeeel!
15,500km ago when i rebuilt my engine I had the same problem, I simply took the heater-motor apart, put some wheel bearing grease on the shaft and bearings and it was good....until a week ago
now it is getting that tell-tale squeek on high speed when it is warmed up and I hit a bump...must be time to grease it again.
Regards,
Keith Cox
1973 124 Spider
1973 John Deere 500c backhoe
1987 Jaguar VDP
2013 passat tdi
2015 cherokee
Keith Cox
1973 124 Spider
1987 Jaguar VDP
2013 passat tdi
2015 cherokee
- 124ADDHE
ill use the high-temp synthetic brake grease this time, maybe ill get 30,000km?
Regards,
Keith Cox
1973 124 Spider
1987 Jaguar VDP
2013 passat tdi
2015 cherokee
Keith Cox
1973 124 Spider
1987 Jaguar VDP
2013 passat tdi
2015 cherokee
Lubing something is repairing/maintaining. If something needs lube then lube it. When a bearing has ran dry then lube it, if that doesn't work then replace it. The throw it away and get a new one mindset nowadays just has me shaking my head. It's not a wheel bearing so if it takes a krap I don't think any lives are in jeopardy
if u have it apart, why not just replace it, why do the lube part and hope it last
may last a day and u be taking it all part again
but your right, might last a life time too
my self THROW IT GET anew one. im not one to try save something, id rather just get a new one
Jim
East Grand Forks MN
1969 124 AS Spider
2017 Abrath
2018 Alfa Romeo 4c Spider
East Grand Forks MN
1969 124 AS Spider
2017 Abrath
- 124ADDHE
Shit Jim, you must be hemorrhaging money or maybe your wife has a trust fund and buys you lots of stuff
for the rest of us, we have to use our money wisely and this means maintaining things. To just throw away something that just needs a little love if one of societys biggest problems, how long can the world survive with that attitude?
Regards,
Keith Cox
1973 124 Spider
1987 Jaguar VDP
2013 passat tdi
2015 cherokee
Keith Cox
1973 124 Spider
1987 Jaguar VDP
2013 passat tdi
2015 cherokee
i am just telling u my opinion on what i do
Jim
East Grand Forks MN
1969 124 AS Spider
2017 Abrath
East Grand Forks MN
1969 124 AS Spider
2017 Abrath
This is certainly right. Normally if heat arises, we often check the motor but it is a good practice to check the fan first.djchan wrote:you really need to take it apart and examine it. If the fan runs well, it might not be the motor. It could be the fan shroud that has deformed alittle from the heat. Take it apart being careful not to lose the clips that hold the heater box up they tend to go flying. If it is the shroud file it down until it doesn't rub anymore.
Who's the guy with a quiet fan and two thumbs? ME!
Lubed and reasembled, good to go. A little electrical lube and a good squirt of ZEP penitrating grease.
