Ignition died
majicwrench
Re: Ignition died
Post by majicwrench »
Don,
Doing a radio gig and missed your call. Will give you a jingle in the morning. A bit late now to call.
If putting your hand over the carb makes it worse, idle jet NOT plugged, no need to mess with it.
If you look down carb venturi is it spitting fuel??
Keith
DocGraphics
Your car is a: 1978 124 spider
Re: Ignition died
Post by DocGraphics »
Keith, done for the eve, will check things out again in the morn, give a call
Don Raugust
DocGraphics
Re: Ignition died
I cleaned both the idle solinoid & the low idle jets last night.
Went to clean the plugs this morn & they looked pretty bad & gapped out to .040+
Replaced them w/ new & now she runs right again.
Had to lower the idle so something must have opened up at least a little & have full throttle response, don't have to feather it.
I do have a miss at idle that starts slowly but increases frequency the longer it idles so once it cools down again I'll go thru the points again & check the timing.
Thank for all the suggestions & help.
Don Raugust
