Brown Wire Fix Question
jimmycakes401
Re: Brown Wire Fix Question
Post by jimmycakes401 »
I was assuming this would all be crimped from the get go. The only things I solder are small wires or reattaching connectors that have be ruined.
Nice to see there are Fiat electrical gurus in MASS. I'm in RI. Hopefully, someday, I WON'T have to bug you for help. :lol:
Post by RRoller123 »
I am NO Fiat electrical guru that is for sure. But I ran an electronics mfg plant for 25 years. The thing with crimps is that the system is always (as far as my experience) designed to carry at least the amperage of the underlying wire/conductor. No connector manufacturer wants their "faston" type connector to be the weak link in the chain. So soldering the crimps to increase current carrying capacity in theory is not necessary. But theory is often wrong in the real world. The crimps have to be good, made with the proper dies and force. And the underlying conductor has to be clean and uncorroded.
RoyBatty
Your car is a: 1975 124 Spider - 1971 124 Sport Coupe
Post by RoyBatty »
For what it's worth.
In general aviation we are instructed and tested in the use of crimp connectors.
The crimped connection should be stronger than the wire itself when done properly.
The only soldering done in GA electrical is for the most part doe on the very fine wires involved in avionics. And usually on the bench.
The rest of the electrical system of an aircraft is connected with crimp connectors.
