2000 FI pistons
the block was most likely swapped. As I recall there was a difference in the blocks where the mounting casting was for the air pump.
fiatS2000
Post by fiatS2000 »
http://img.photobucket.com/albums/v27/e ... 1169527891
This engine that I removed from a crashed low mile 85.5 spider was also stamped LANCIA.
LE pistons
Thanks again everyone. I removed the valves and lapped them. The exhaust had smoe pitting that cleaned up pretty good. Installed new valve seals while everything is apart. Will clean the threads in the block as suggested. Everything just takes me longer than I want.
every once in awhile, things go just as planned, but not very often
