Can we talk 124 Coupe?
- riverdadd
- Your car is a: 1975 Fiat Spider 1977 Alfa Spider
Re: Can we talk 124 Coupe?
i had a coupe when i was a kid..... wishing i had held on to it
- RoyBatty
- Your car is a: 1975 124 Spider - 1971 124 Sport Coupe
Found this front spoiler at Midwest-Bayless.
- seabeelt
- Patron 2019
Very Nice!
r/
r/
- RoyBatty
And this is what happens when your dual idf 40 manifold is not designed for a spider or coupe.
This shows the angle difference in the face of the manifolds where they meet the head.
- RoyBatty
Hi Mark,
Yes, that's what I surmised.
Not obvious to a guy like me until I try to mock it up into position.
- RoyBatty
So I got my waffle manifold from Italy today.
And now I know why it was too good to be true.
I already have it at a shop to weld up the hole and build the area back up on the intake runner.
My question is, what were they trying to make clearance for?
I am about to go thru the translation process to deal with the ebay seller in Italy to try and get some compensation for the repairs.
It was advertised to be "used in excellent condition".
Grrrrrrrrrrrrr
Grrrrrrrrrrrrr
- azruss
I did this conversion on a 79 2L in a 70 spider. As I recall, I couldn't put the manifold on as there was interference with the brake booster/MC. I suspect that is what the grinding was all about. I ended up cutting all the runners out of the manifold and switched them all around and re-heliarced so the carbs sat vertical and had a forward offset to give me clearance in the back.
- RoyBatty
Hi azruss,
Sounds like a nice job of fabrication.
Just the opposite of what happened here.
This grinding is under the front intake runner and cooling passage.
I was thinking either alternator or distributor clearance.
- RoyBatty
Sooo,
I got the twin IDF 40's installed and synched up.
Annnd....The Coupes balls have dropped!!
OH MY GOD what a difference.
I will be reworking my throttle linkage to incorporate a cable between the pedal arm and the bellcrank that drives the throttle arms.
The hip hop tendency of the stock solid linkage is only more pronounced with the additional response and power. The cable should remedy that problem.
Good job at recreating the stock type IDF linkage, tho!
- RoyBatty
Thanks Csaba,
Here is the first run thru of the cable system. I'll clean it all up once I have it tailored to my liking.
Seems to work ok with the elimination of the hippity hoppity that can happen with the engine rocking in it's mounts with the solid linkage.
- spidernut
Nice, Tom! I'm looking forward to seeing and hearing it in person. What's next? The bodywork?
John G.
1977 Spider (Sold 2017)
1979 Spider (Sold 2015)
1980 Spider (Sold in 2013)
1981 Spider (Sold in 1985)
