Engine Fan Direction
gjacobs101
Post by gjacobs101 »
Hello,
I recently got my radiator fan working again, turns on when engine hits 190. Yeah! The original wiring harness was not there and it had been hacked (badly) previously. There are 2 wires that hook up the fan, I suspect polarity of these will drive the fan clockwise or counterclockwise. Question is should the fan be blowing from engine to outside, or reverse outside to in. Currently it spins to push air from engine bay to outside.
Does someone know the correct direction?
-George
kmac33
Your car is a: 1974 Spider
Re: Engine Fan Direction
Post by kmac33 »
The fan should be pulling air through the radiator into the engine bay.
Kevin McMullen
1980 Fiat Spider
2013 Subaru WRX
gjacobs101
Ah, then mine is going the wrong way. I will swap the leads.
-George
