After market wiring thru the firwall
Doug12
Post by Doug12 »
Hi Doug from Maine here. I've got a 1970 spider. How difficult is it to drill thru the fire wall to install wiring for an after market water temperture gauge. While I'm at it I think I'll run the radio wiring thru this same hole for direct fuse to battery hook up. Any thoughts on this? Many Thanks Doug in Maine
azygoustoyou
Re: After market wiring thru the firwall
Post by azygoustoyou »
Hi Doug,
The firewall is thin. Just be careful not to drill into anything on the other side. You could get a rubber gromit from your hardware to put into the hole so you don't fray your wires.
velozi
Post by velozi »
I did the same thing but found a hole with wires where I was able to use.
baltobernie
Post by baltobernie »
The main bundle, which exits near the brake booster, usually has enough room to handle another 18 ga. wire. See if you can gently feed a thin coat hanger (with a blunt tip) thru along side the bundle. Tape your gauge wire to the end on the inside, and fish it back to the engine compartment.
