which hose?
Zmatt
which hose?
Post by Zmatt »
I'm at the point where i need to drain the fuel tank and remove it. The only problem is my crap shop manual only has written directions and a picture of the 124 sedan fuel tank. I didn't think that would be a big deal until I looked at the tank and saw this
Which line should I remove to siphon the fuel? And what are all of these lines for.
Re: which hose?
1. is fuel feed to pump
2. return from carb
all others are vapor hoses to the separator that then goes to the evaporative cannister.
If you plan to siphon from the tank, it has to be 1
Zmatt
Re: which hose?
Post by Zmatt »
Ok thanks for the fast reply. I can get back into the garage.
