Here is what I found:
Paint chips. The paint job is starting to go...
Dent on side panel towards the rear, passenger side
Rust in the wheel wells
Rust in the front fenders (the piece that goes down between the front wheel and door)
Missing badges (not in the trunk)
Seat belt plastic surrounds broken
Tear in top (in corner) and all loose inside, not attached to the rods that cross. Top is in poor condition and will need to be replaced. Metal structured will need to be reconditioned as it has rust in most rods.
Seats are loose and the nut inside the side of the seat is loose as well, so no way for me to tighten the bolts to make it stay secured. The seat looked like they were not finished, not anchored correctly
Rear seat area is apart, no side panels (in trunk), no trim (scattered over the rear seat and in the trunk)
Center console will need to be replace, see photos, the trim is gone, ashtray will need to be replaced, the material used to cover the console is loose and there are areas they used silicone to keep it in place
Wires under the dash hanging, or cut. Could be when they removed the radio
Cracked instrument wood panel
Dash needs to be replaced
Steering wheel needs to be replaced
A lot of small pieces of trim missing, the plastic trim that goes in the doors to align when closing are broken
I did not try to lower the windows nor activating the windshield wiper and washer
Engine has a cracked air duct (big hose that goes from the intake to the air flow meter). Looks like it was temporarily fixed with silicone
Bent oil pan
Oil leak around the header
Brakes looked in good condition (new lines, new pads, rotors looked fine)
Exhaust (muffler) still in good, almost new condition
Suspension looks good
Trunk area (inside) in good condition
New battery
