coolant flush
coolant flush
I want to flush the coolant system on my 1981 Spider 2000. The decision is do I do it the old fashion way or do I take it to a local service facility and have it flushed with one of the machines that cycles out the old fluid and installs the new. I know its less expensive to do it at home. One of my co-workers claims having it done professionally is the best way.
All thought would be appreciated
Jimb
Your car is a: 1985.5 Volumex
Re: coolant flush
Post by Jimb »
Well, considering a fluid flush is done somewhere between 3-4 years, why not have it done professionally? The difference is cost is about a dollar three eighty :)
mdrburchette
Re: coolant flush
Post by mdrburchette »
There's no evidence the "professional" way has any advantages over the old fashioned way. Some shops use a system that recycles the coolant by filtering your old coolant and adding the chemicals that have broken down over time. If you don't have a method of disposal, having someone else do it seems logical.
1972 124 Spider (Don)
1971 124 Spider (Juan)
1986 Bertone X19 (Blue)
1978 124 Spider Lemons racer
1974 X19 SCCA racer (Paul)
Re: coolant flush
using a flush machine is far superior to just draining and refilling. A proper flush machine changes the direction of flow to dislodge any debris and will completely drain the system. Just opening the radiator drain leaves the cooling system half full
