DIY Bumper Delete Lights
Re: DIY Bumper Delete Lights
Good morning. I bought these from Bruce's parts about a year and a half ago( about $400 Can. after exchange and delivery to Oroville WA.). I looked around for prices and after missing out on a set on e-bay I ended up with these. I thought with the exchange at the time these would work/ best I could do. They are the solid rubber ones with a piece of flat bar for a support. Suposedly they work better in the cars prior to the tube bumpers. I'm working on a way to mount in the rear tube holes.( going to have to pull the fuel tank I think) 1 1/2 inch pipe with part of the top & bottom cut out to access the bumperette flatbar with spacers ect. I'll try and get some photos.
Chris
B.C.
Chris
B.C.
Sorry Kuhndg, I just posted the pics for Narfire so it's not my car. I do have the same bumperettes he does that came from Bruce's Parts Bin and even though they were meant for the early bumper cars the fit isn't exact. Here's a pic of how it fits to the body of one of my 72 model projects:
The back fits better:
1972 124 Spider (Don)
1971 124 Spider (Juan)
1986 Bertone X19 (Blue)
1978 124 Spider Lemons racer
1974 X19 SCCA racer (Paul)
- ga.spyder
Denise,are you sure that rusty car can support the weight of the bumper blocks?
The original bumpers are probably laying in a road somewhere!!
Craig
Craig
Craig Nelson
Fling It Around Turns !
Watch it Craig. You're talking crap about my racecar! Geez, see if I let you play in my shop anymore.
Hi, if you want to see a larger photo(s),do the private message thing and I'll e-mail
Chris
Chris
Mark, since you make a living working on these you should know that Fiat built a feature into their cars that is meant to reduce weight as the engine wears to maintain horsepower. This particular car had a badly worn out engine.So Cal Mark wrote:so those holes are from acid dipping for lightness?
just the opposite of humans, that gain weight as they age?
- ga.spyder
That is the way we lighten vehicles in the South.Just let em rust in the yard for 10 years.A good wind will blow hickory shells at it ,and there is your media blast.Then prime er up with some good cans of Rust o leum,and drag it into the living room!
Oh,yeah..remove the family of possums and send them to SoCalMark.Seems like he has a taste for them!
Craig
Craig
Craig Nelson
Hey Craig,I take it your from GA. The car I kind of modeled mine after was from Savana. Google "ragno volante" flying spider . Perhaps its yours or someone you might know. Looks great though.
Chris
Chris
- ga.spyder
Hey Narfire, its not mine and I dont know the owner.I am a long way from Savannah,but I have seen the pix of that car before .It is a true beauty,and he did a great job on it.I hope yours turns out just as nice,then you can bring it to FFO and show it off!!
Craig
Craig
Craig Nelson
Hi Chis & Craig,
Thanks for the compliments on Ragno. Let me know if I can provide you with any info.
Craig,I was taking the inner wheel liners off among other bits for prep. of a re-paint and took these(closeup). I did'nt mess with any edit stuf at photobucket so maybe a bit bigger
,http://i708.photobucket.com/albums/ww88 ... oseup1.jpg I still can't seem to get the photos up.
Gotta have a nerf hammer for this computer thing.
Chris
Chris
I know this subject comes up from time to time and there are many different ways solve this problem. I found this site while looking for a rear fog light. They have many different styles of indicators that could be used. Check it out. http://www.s-v-c.co.uk/lights_indicators.html I have also run across a couple other lights that may work. One was the indicators from an early triumph, the other was the indicators from an early Jeep CJ. Both are round and would look nice just dont know the dimensions and if they would fill the holes on the Spider. I just thought of this while typing. '65 and '66 Mustangs had indicator housings that may work too.
Ok first comes the apology.... I didn't follow through as promised in regards to getting information about my diy signals. I apologies and will say several hail whatevers to the Fiat Gods... now on to the good stuff.
2 Parts are required per side for the turn signal DIY.
1- 2" Sealed Marker Lamp Kit NAPA Part Number 30503y1
http://www.napaonline.com/NOLPPSE/(S(4e3bdz55q0q05omjjnwfnu45))/Detail.aspx?R=LIT30503Y1_0218607301
2- Grommet Cover for 2" Mounts Napa Part Number 30712-1
http://www.napaonline.com/NOLPPSE/(S(4e3bdz55q0q05omjjnwfnu45))/Detail.aspx?R=LIT307121_0006416607
