I was removing a tail light assembly recently using an 8mm ring spanner and I dropped it. There is only about 2 inches for it to fall before it would hit the cable running along the bottom of the space.....no where else for it to go. Think I could find it ????? nooooooooo. No amount of magnet or lite helped. Had to go get a new one....
Baz
What did I do wrong? Argggg!
- fiasco
Re: What did I do wrong? Argggg!
Steve Eubanks
- perthling
- Your car is a: 1974 124 Spider
Many years ago (probably around 2000 or 2001) I was working on my Spider. At the end of the day I couldn't find my 13mm socket. I searched everywhere but to no avail. Last year I was fixing up the wiring to my fuel pump and found the socket wedged between the bottom of the fuel pump and the nut holding the front inboard corner of the fuel tank to the trunk floor. So they do turn up eventually!Baz wrote:I was removing a tail light assembly recently using an 8mm ring spanner and I dropped it. There is only about 2 inches for it to fall before it would hit the cable running along the bottom of the space.....no where else for it to go. Think I could find it ????? nooooooooo. No amount of magnet or lite helped. Had to go get a new one....
Baz
_______________________
Perthling
1975 Fiat 124 CC (project)
1969 Fiat 124AC (project)
http://www.fiatlancia.org.au
Perthling
- ga.spyder
Our cat has been missing.Hmmmm....
Craig Nelson
Fling It Around Turns !
- Your car is a: 1981 Spider Turbo - missing the turbo
Well on the weekend I was cleaning out my 2002 Calais ready for TradeIn this week and I found one of my Phillips head screwdrivers inside the center console ( under the console and inside the aircond piping ) and a missing 10mm spanner in the rear tail light assembly - bugger if I know how it got there ! !
THE FLEET
2014 Abarth "SS"
2014 Abarth "SS"
- fiasco
I hope so, 'cause that was totally my favorite washer!Baz wrote:... So they do turn up eventually!
-- se
Steve Eubanks
