Does anyone know if you can turn power windows to role up without taking the electric motor out? They only seen to work when they feel like it..If not how hard is it to change to role up or put new motors in?
power windows
- Your car is a: 1970 fiat 124 spider 1979 2000 spider
power windows
1970 124 sport spider
1979 2000 spider
1979 2000 spider
Re: power windows
you would have to change the window regulator to convert to manual roll up windows
- Makita
Re: power windows
Have You this tool?
http://www.nic.fi/~makital1/spider/
Pininfarina Spidereuropa -84
Fiat 850 Coupe -66 (project)
Alfa 156 2.0TS -98
Alfa 156 2.0TS -98
Re: power windows
I've seen it before but where can i find one?
1979 2000 spider
1979 2000 spider
Re: power windows
Dartme have you checked the levers to make sure they are working correctly first. I have been dismantling a 74 and have found that the grounding of various parts is sketchy at best. I would check all the connections and continuity of the wires from the switch to the motors and all the grounds. Use some dielectric grease in the connectors as this will help them from getting corroded.
