I am going to need a shifter boot for my 5 speed conversion. A new boot is not a problem but how is it secured to the consul/lever ? Is there some sort of clamp ring or what . Any help appreciated.
Baz
5 speed gear lever boot thing
Re: 5 speed gear lever boot thing
Are you talking about the outer shift lever boot? It is clamped onto the shifter console with an aluminum ring. I think you can still get them from Vick's.
1972 124 Spider (Don)
1971 124 Spider (Juan)
1986 Bertone X19 (Blue)
1978 124 Spider Lemons racer
1974 X19 SCCA racer (Paul)
or, are you talking about the inner rubber boot? it too is available from that vendor. if i would EVER get my copy of the new catalogue i could quote you the current pricing.
it is assembled to the shifter lever without fasteners. is it possible that you are missing the stamped steel plate that is supposed to cover this opening? that plate secures the rubber boot in place very nicely. always a good idea to keep the rubber boot in good condition, because it helps keep out dirt, noise and heat.
the following is a shameless plug for my product. anyone taking offense, should stop reading now...
i have a few of these rubber boots that i sell along with a purchase of a MICHIGAN SHORTER SHIFTER. i sell my boots at cost, but only with a sale of a shifter.
- Europa
- Your car is a: 1983 Pininfarina Spidereuropa
Catalogs from IAP & Vick Auto are available online in PDF format.
http://www.international-auto.com/ecata ... atalog.pdf
http://www.vickauto.com/Catalog/Vick%20 ... atalog.pdf
Mike, are you referring to the printed catalog?
1983 Spidereuropa
Verde Scuro
Verde Scuro
yup. they both have a new one in print, and distribution. i have not seen my copy of the new Vick catalogue. i always use them as gift suggestions for Christmas and my birthday. makes a great way for one of the daughters to get dad something he can actually use (and wants).
What I have is just the stick poking out of the consul. So I guess I need the plate and an inner boot? and the outer boot and retaining ring. Do I have this right ?
Any idea who might sell this stuff ?
Baz
Baz
If you're looking for new, Spider Point may be the biggest distributor and most likely has what you need:
http://www.spider-point.com/
These parts also come up regularly on Ebay. Plus I'm sure there are members with parts that are for sale. They'll probably see it on this subject, but if you don't get a response, you could try posting on "Parts Wanted".
Are you familiar with the usual vendors for our cars?
Ron
Ron
rubber inner boot available new as i suggested
vinyl or leather outer boot also available from our standard vendors
retaining ring ditto
stamped steel plate prolly only via used parts
decorative trim outer cover....if you buy it new, will it match the rest of the wood in your dash?
Thanks men...I will manufacture the timber cover but will need the plate, boots and clamp. I will try the vendors as you have suggested. Appreciate the input...
Baz
Baz
