Back at it- need help
Yadkin
Your car is a: 1974 Spider
Post by Yadkin »
After several years of pre-retirement "busy" ness and delays by my painter I've got the car back into my tiny garage and final assembly. I looked through all five bins of materials and can't seem to find the front hood latch. I'm probably not using the correct term which is why a word search was futile. This is the mechanism close to the hood hinge on the driver's side. It looks to be held in place with three screws in a triangular pattern, and holds the spring loaded rod to keep the hood vertical when it is fully opened.
I'd be much appreciated if someone could snap a picture of theirs so I can have another clue as to what I'm looking for.
Zoofly
Your car is a: 1978 Fiat 124 Spider
Re: Back at it- need help
Post by Zoofly »
I think this is what you're looking for.
2020 124 Spider Abarth
2019 Alpha Romeo Stelvio - sold
1977 Triumph Spitfire
2017 Fiat 124 Spider Classica - sold
1999 Jaguar XK8 - sold
1998 BMW Z3 - sold
1988 Pontiac Fiero - sold
Yadkin
Post by Yadkin »
Zoofly wrote:I think this is what you're looking for.
That's it, thanks. I looked through my 5 bins of bits and it's nowhere to be found. Thankfully Vick's makes a reproduction, and it's on order.
Yadkin
Post by Yadkin »
Can anyone identify this part? I thought it was an air shield under the radiator but I can't figure out how to attach it. It's a little under 27" wide, heavy rigid plastic with a steel bar at one long side.
I can't recall ever seeing anything like that on a Fiat spider. Perhaps someone added it as a protective cover of sorts?
F16Waldo
Your car is a: 1983 Pininfarina Spider
Post by F16Waldo »
18Fiatsandcounting wrote:Perhaps someone added it as a protective cover of sorts?
I think Bryan may be right. Eerily similar to the size and bolt hole pattern as this "oil pan cover" installed on my 83 in 2019.
https://www.vickauto.com/parts/oil-pan- ... u-54-0300/
W
Damsels Rescued...Dragons Slain
Yadkin
Post by Yadkin »
W
You gave me a clue, thanks.
Installs very easily onto the front tow hooks on either side of the radiator and into the back flange of the crossmember. Does not include hardware.
Yadkin
Post by Yadkin »
It has the correct width to bolt onto the tow hooks, but I only have one hook. And the profile is all wrong to pass under the oil pan. My guess, this part got mixed up from another car at the shop it was in for several months.
