Hood Latch Cable
- Your car is a: 1980 Carb 2000 Spyder
Hood Latch Cable
I took this car apart many years ago and have lost the pictures due to a computer crash. I need to know, on a 1980 spider, how is the cable held fast to the front firewall? I see no holes for screws around the latch that a cable catch might be attached. Thanks in advance
Bill
1980 Carb Spider
!966 Maserati Sebring
1989 Full Size Bronco
!989 Bronco II w/V6
1961 Buick Special
!969 El Camino
Bill
1980 Carb Spider
!989 Bronco II w/V6
1961 Buick Special
!969 El Camino
- focodave
Re: Hood Latch Cable
Believe it or not -- there is no clamp that holds the cable housing to the firewall near the latch assembly.
The outer housing is fixed in position, relative to the inner cable, at the pull handle assembly bracket located in the passenger compartment on the driver's side of the car.
No need for a solid mounting point for the outer cable housing near the latch mechanism for it to work properly.
1970 MGB GT (my other hobby)
I ended up making one anyways just to play it safe. Attached it to the stud on the side of the latch where the cable goes into it.focodave wrote:Believe it or not -- there is no clamp that holds the cable housing to the firewall near the latch assembly.
- Yadkin
- Your car is a: 1974 Spider
I had this same question, but no access to my PC, and searched my parts bin for about an hour before giving up. Now when I get back to it (the car is two hours from where I now live), I can put the hood back on and not worry about not being able to open it again.focodave wrote:Believe it or not -- there is no clamp that holds the cable housing to the firewall near the latch assembly.
Thanks for your clear and concise answer.
