Auto to Manual Swap
whatsupwill99
Auto to Manual Swap
Post by whatsupwill99 »
Hello all, I'm looking into buying a running project '82 spider. The price is right, but my one hesitation is its auto transmission. I've currently got an '81 parts car with a manual, that to my knowledge has a sound transmission. Does anyone have experience swapping an auto to manual on one of these? Was it such a pain in the butt to where I should just wait for another to pop up?
-Will
FiatFarm
Your car is a: 1972 Fiat 124 BC Sport Coupe
Re: Auto to Manual Swap
Post by FiatFarm »
Everything will bolt together from one to the other.
And there are always other owners that are looking for the automatic parts to convert their Spider, so there is good resell value.
Be very careful removing the shifter and the center console, the plastic gear selector indicator is very fragile and will easily break, if it hasn't already.
Need to change the radiator and transmission cooling lines from the engine compartment.
Underneath you'll need to change from the flexplate(flywheel) to the front part of the drive-shaft (whole drive-shaft is easier).
SteinOnkel
Post by SteinOnkel »
There may be a forum member here that would possibly take all the automatic bits off your hands.
Cooter
Your car is a: 1979 spider
Post by Cooter »
Did you double the swap? Do you have any parts left from the automatic?
