I have a spare rail in good condition, it has no physical damage and the nuts thread well, but it is pretty old and hasn't been used in many years. The question I have is what you folks think might be the best way to clean it, and flush out this old rail? It looks quite good, but there are some minor white powdery deposits visible inside that I think I should remove or they could cause problems with the injectors.
I was thinking of soaking it in vinegar overnight and then flushing it with hot water and then a pressured air cleanout. ?? It won't fit in my ultrasonic cleaner, it is too long. I suppose I might be able to get one section at a time in the UC, but not sure how well that would work.
I suppose I could spray an entire can of brake cleaner or similar solvent through it and maybe that would flush it well enough??
Rail to be cleaned: The pictures don't show overly well, but you get the idea.
