Will not stop running when ignition is turned off
vjr124
Your car is a: 1981 Spyder 2000
Post by vjr124 »
hi all... new to the forum, but I have a unique issue. once the car is running, when I turn off the ignition switch, it keeps running. I have disconnected the 2 white connectors down stream of the ignition switch which I believe isolate the switch, no joy, it keeps running. Suggestions on where to look next.
Re: Will not stop running when ignition is turned off
Its posible for the voltage regulator on the back of the alternator to short and cause this issue.
Try disconnecting the violet/black wire on the back of the alternator and see what happens. The battery warning light will not lite with the wire disconnected but if the car shuts off with the ignition switch "off", the voltage regulator usually needs replacement
seabeelt
Patron 2019
Patron 2019
Post by seabeelt »
What year car? Could be internal to the ignition switch
Bagneaux
Your car is a: 1978 124 Spider
Post by Bagneaux »
My 78 124 Spider did this. Ignition switch replacement solved problem.
