Drain Holes in Floor Pans?
SteinOnkel
Post by SteinOnkel »
Hey guys,
so I'm just about ready to put the new carpet in.
I noticed this car has quite a few triangular holes in the floor boards.
Are these drain holes? Should they be left open? Or should I seal them up?
Steiny
Re: Drain Holes in Floor Pans?
Yes, drain holes. Good idea to leave them open.
SteinOnkel
Hmm some of them were under the sound-insulating tar mats. Weird.
Maybe they flooded the cars with primer in the factory?
In any case, there were what as a scientist I would call a "shitload" of holes (not from rust ;) ) in the floorboards. Never seen so many in a car.
wetminkey
Post by wetminkey »
My '79 is the same,...multiple, triangular holes (the metal stamped 'open" on two long sides of a triangle) factory-punched into the floorpan. All of them face the rear, for drainage/evaporation of moisture in the car.
I'll sure not mess with moisture-control in a convertible,...I'll just try to keep it clean and dry, as much as possible.
Todd.
1988 Mazda RX-7
1979 Fiat Spider 2000
1976 Camaro
1972 VW Superbeetle
1969 Ford F100
1968 Mustang coupe
SteinOnkel
Yes, those are the ones. My s/o was a little...overzealous... with the seam sealer. I will be scraping it out to free up the triangles.
