advice on registering 77 in Cal?
This section is a bulletin board for your Fiat club
StuartSpencer
Your car is a: 77 Fiat Spider
Post by StuartSpencer »
Moving to the SF area and have a 77 Spider with all of the emission stuff removed (registered as classic vehicle in WA and no emissions testing needed).
I saw that there are California 'historic vehicle' plates available but can not tell from the California DMV site if I still need to pass emissions.
Any advice would be appreciated.
-Stu
ward00
Your car is a: 1975 Spider
Re: advice on registering 77 in Cal?
Post by ward00 »
You will have to reinstall ALL smog equipment and then pass the test if your car is 76 or above. There is a bill AB-210 to try to change the date to below 83, but I'm not holding my breath that it will pass.
75 Spider
75 Sport Coupe restoration
ward00
Post by ward00 »
ward00 wrote:You will have to reinstall ALL smog equipment and then pass the test if your car is 76 or above. There is a bill AB-210 to try to change the date to exempt all vehicles below 1983, but I'm not holding my breath that it will pass.
75 Spider
StuartSpencer
Well crap. None of the air pump or EGR valve stuff has been installed for 15 years...
geospider
Post by geospider »
With a '79, I will be replacing the "SMOG" stuff, for a day of being legal, then go back to the single plane-32/36 I current;y run. A common everyother year ritual for us here in CA.
Not exactly sure what a 77 needs but the 79 set up is horrible
good luck
Concord, Ca
Geo
scrapironchef
Your car is a: 79 Spider
Post by scrapironchef »
Find a relative who lives outside the AQMD's bay area enforcement zone and register it at their address, you'll have to have the car smogged initially, but it won't be called for again unless you sell it.
Don't ask me how I know...
SteinOnkel
Post by SteinOnkel »
Or find a smog guy. Everybody in CA that likes cars has a smog guy. Ya know, the guy who pushes a button and *poof!* you have a valid smog certificate.
Just ask around.
cakewalk
Your car is a: 1981 Spider 2000 2018 124 Spider
Post by cakewalk »
Did you get your car through smog?
Getting a carb'd car through smog if you're in an enhanced smog area will be very difficult.
There are a few very good shops in the area - probably the best is Wine Country Motors in Napa. Kelly Dicker is the owner and he's been a Fiat guy for some number of years.
If you're still having issues or need help, Kelly is definitely your guy.
Wine Country Motors
707-255-8697
http://wcmotors.com/
