How to mount the battery in the trunk
- Your car is a: 1972 Fiat Spider 124
My car has the battery in the trunk. When I purchased the car it had no battery. I do have the plastic cover. Can someone send me a picture and what are the parts I need to hold the battery in place?
Glen
Kitchener ON Canada
73 Fiat Spider 124
Kitchener ON Canada
73 Fiat Spider 124
Re: How to mount the battery in the trunk
Plastic cover goes on then metal brace overtop of cover
http://www.fiatspider.com/f08/viewtopic ... 19&t=17102
- toplessexpat
- Your car is a: 1976 Spider 1800
.... unless you've got a later spider when it's on the side of the trunk.
A
A
HMMMMMMMMMMMMMMMMMMMMMMMMMMMM
- Dawgme85
- Your car is a: 1977 124 Spider - Shelob
On my'77, the battery sits in the battery box with the negative terminal on the right side. It is held in place by an angle bar that spans across the top of the battery along the rear edge, with 2 J-bolts which hook into holes in the battery box and pass through corresponding holes in the angle bar. Nuts then clamp the battery into place. The plastic cover is then located on the studs which are attached to the flanges of the battery box and mating nuts keep it in place. There's also a thin foam gasket between the cover and the battery box flanges. Hope this helps.
1977 Spider 1800 (SHELOB - driver)
1970 124 Sport Spider (99% complete barn find, now in my garage, awaiting restoration)
- Your car is a: 1979 spyder 2000
i can send photos ,
- toplessexpat
Isn't it?4uall wrote:HMMMMMMMMMMMMMMMMMMMMMMMMMMMM
I could be wrong....
4uall always seems to be lost in thought...... now we know why?
