ignition problem
Tappy
Your car is a: 124 spider 2000 1979
ignition problem
Post by Tappy »
Hey guys , did it again :cry:
I did some rewiring on my spider , and ofcorse it wouldt start @ first , seemed like i i did some bad rewiring , espacialy to the coil switched the poles there , gave me some smoke @ the coil and the ditributor cap
However i let cool down , rewired it correctly , and the car did run for over 5 min or so , then i had to shut it down becouse the waterpump doesn't seem to work (after the flushing discussed in another post , i probably get back on that after i fixed this )
Now the ony thing the coil does is getting hot , very hot i screwed out a spark plug , but i see no more sparks :( , i dont understand this becouse it has run like 5 min ago ...
Is the coil getting hot i sign that it works? how can i check this ? should i look in the distributor cap ? (nota i dont know how to adjust timing on the egnition )
all help welcome i got a few hours to fix it before my future wife comes home and i really dont want to tell her i f*cked it up , again (this shuld be our marriage car in a few weeks )
so pls help :oops:
FineItalianAutomobile TechnologyImage
Tappy
Re: ignition problem
Post by Tappy »
did some research i placed an ohmmeter between the b+ and d connector on the coil ,all other cables disconected , te ohmmeter reads 3.5 Ohm so i guess this too much , probably burnd trouhg wirein the coil ?
if im right this is the primary winding and it should be between 0.75 and 0.81 ohms ?
the other thing i tested was one of the contacts b+ to the middle wire (highvoltage wire) i mesured 7600 ohms there if i'm right this should be 10.000 tot 11.000 ohms
can someone confirm that the coil needs replacin ?
thx
Tappy
Post by Tappy »
Problem still not solved :(
first i'll discibe what i have , i have a coil , no control module , and a dizzy mounted on the cam so i think this is a breaker point ignition system.
I'll explain as good as posible what i did :
*i've tested the power when ignition switch is on , and theres 12v going to the + of the coil , so far so good
*i've also tested one of the sparkplugs out of the motor , grounded the shell and test started , no spark :(
so i did some extra test with a lamp bulp to determ what could be wrong
normaly when you connect a bulp to the - of the coil , and the other wire of the bulp to the - of your car and you try to start the light should go on andof rapidly ( get back on this one later**) i tested it but the lamp wouldn't go on
theres power on the + from the coil so that is not the problem either
could be that the distributor lopes dont open , but i opend the distributor cap , and cranked the motor a bit till they where open ** here it comes , the testlamp does not light , not even with the points opend ?? the coil gets hot also with the lopes opend ??
cansombody help me i realy losing it , not mensionning the future wife...
mdrburchette
Post by mdrburchette »
Is it a points distributor or electronic, Tappy? You have a 79 model, coreect? If you had smoke coming from the distributor, I'm wondering if you've got a faulty pickup coil (electronic). I can't help you on the coil ohm readings since my books don't go over 1972.
1972 124 Spider (Don)
1971 124 Spider (Juan)
1986 Bertone X19 (Blue)
1978 124 Spider Lemons racer
1974 X19 SCCA racer (Paul)
Tappy
Post by Tappy »
a point distributor ...
