starters
dmwhiteoak
starters
Post by dmwhiteoak »
My starter died on me today but thankfully I was home. Had power to the starter but could not get it to latch up until I wacked it with a hammer. My question is did Fiat make two different size starters or is the small one in the pic a gear reduction ? It wasn't as easy as some say a gear reduction starter is to remove but I can plainly see that the other one is really going to be a pain to install.
The larger is off the parts car and I have 2 more just like it. I will take the smaller one tomorrow to try and have it rebuilt. For some reason when the starter did work as I was persuading it , it was magnetized. My hammer stuck to it and was tough to get it off. What do y'all think ?
Dennis Modisette
1972 124 Spider
2003 Chevrolet Z71
2007 GMC Yucon
azruss
Re: starters
Post by azruss »
the larger one is OEM. the hammer trick tells you the starter is probablly ok. just needs brushes at best and the issue is with the solenoid. dirty contact plate and/or worn solenoid shaft track not allowing the contact plate to connect the 2 lugs with full pressure.
bobplyler
Re: starters
Post by bobplyler »
The smaller one isn't a gear reduction starter.
1979 Fiat Spider (since new)
1999 Honda Shadow VLX 600
Kevin1
Re: starters
Post by Kevin1 »
If you are swapping out the starter anyway, switching to a gear reduction starter is a great choice.
Re: starters
the hammer trick actually reveals a serious problem with the starter. The armature is stuck to the field windings and the shock of the hammer dislodges the armature so it doesn't drag. Repeatedly hitting it hard enough will break the magnets in the starter. New field windings aren't available anymore, so if the armature has worn into them rebuilding would require used windings. This is pretty typical with most rebuilt units and one reason why the failure rate on rebuilds is so high
htchevyii
Re: starters
Post by htchevyii »
My '82 had a smaller, (than the Marelli) Bosch starter in it.
Trey
dmwhiteoak
Re: starters
Thanks guys for the info. The smaller one is a Marelli and built for Fiat but parts are not available for a rebuild, so I'm told. Had the starter checked at 2 different places and said starter motor had problems. Not going to try and install the good mammoth starter I have so if someone needs it , it's yours. I have a gear reduction starter on the way.
Dennis Modisette
1972 124 Spider
2003 Chevrolet Z71
2007 GMC Yucon
dmwhiteoak
Re: starters
The gear reduction starters are the cats meow. Took less than an hour to install and that was also including fixing what I tore up or removed to get the old one out. Thanks Ramzi.
Dennis Modisette
1972 124 Spider
2003 Chevrolet Z71
2007 GMC Yucon
fiat218
Re: starters
Post by fiat218 »
dmwhiteoak wrote:The gear reduction starters are the cats meow. Took less than an hour to install and that was also including fixing what I tore up or removed to get the old one out. Thanks Ramzi.
I agree , all my fiats will have one
