Looks like the clutch cable pulled through the firewall. Is this common? If so what is the best approach to fixing it? I was thinking maybe get two pieces of flat steel and bolt on eon each side so the damaged section of the firewall is sandwiched between. I don't really have access to welding equipment. Anyone else had to do this repair?
