Pininfarina Headlight Relay
davery
Your car is a: 1985 Spider
Post by davery »
I had read somewhere a while ago that the 83-85 Spiders had a headlight relay. Is that true? If so, where is it located?
Don Avery
Dayton, OH/Sarasota,FL
1985 Pininfarina
2011 Eos
2012 Mercedes E550 Cabriolet
ORFORD2004
Re: Pininfarina Headlight Relay
Post by ORFORD2004 »
Yes, Under the glove box.
Last year my low beam was not working. Change the relay and everything is OK
davery
Post by davery »
ORFORD2004 wrote:Yes, Under the glove box.
So can I use a 55/65 watt headlight without adding a relay?
Don Avery
1985 Pininfarina
2011 Eos
ORFORD2004
Correct
davery
Post by davery »
ORFORD2004 wrote:Correct
I am starting to do some research on what to use.
I found a Bosch kit for $45 pair w/o bulb. What about using a 55/100 Hella bulb?
Any suggestions from anyone?
Don Avery
1985 Pininfarina
2011 Eos
ORFORD2004
I just put HID 55W in my Hella. cost me around $50.
davery
Post by davery »
ORFORD2004 wrote:I just put HID 55W in my Hella. cost me around $50.
How is the high beam?
Don Avery
1985 Pininfarina
2011 Eos
