Pick-up cable from distributor
Hudini
Post by Hudini »
Hi, I need help. I have 79 spider 2000.
I have problem with distributor wires. In distributor wires are completely naked, no insulation. I want to make a new cable by itself. Now, in distributor we I have 3 wires (1 is ground, 2 are pick up signal). But, on connector that goes to coil, i have 2 wires. Where the ground goes.
htchevyii
Re: Pick-up cable from distributor
Post by htchevyii »
Here's a picture that shows where the ground wire mounts to the dist. If you do decide to buy one, they are much less expensive, (30 bucks or so) from the Fiat vendors, but thus was the best pic that I found.
http://m.napaonline.com/Tablet/parts/Pa ... 0065181524
Trey
fiat218
Post by fiat218 »
htchevyii wrote:Here's a picture that shows where the ground wire mounts to the dist. If you do decide to buy one, they are much less expensive, (30 bucks or so) from the Fiat vendors, but thus was the best pic that I found.
See that screw in your photo?
That where it goes on to
Your welcome
fiat218
Post by fiat218 »
Ground goes to that screw
Hudini
Post by Hudini »
that I now. But, on the other side of the cable??? In distributor are 3 wires, blue, brown and ground. On the other side are just 2 wires. What happend with ground wire?
fiat218
Post by fiat218 »
Here is how mine is, grounded in the dizzy, just like my photo shows, with the othe piece fasten down in the dizzy too
Black wire and green wire go to the watchama call it :) ,ground as you see short stub
Other end of the wire is blue wire and brown wire, connected in a plug,that plug slides on the module, that most likely is mounted behind the coil, coil is mounted to a ? Can't recall the name
Ground is on the dizzy end
fiat218
Post by fiat218 »
Hudini wrote:that I now. But, on the other side of the cable??? In distributor are 3 wires, blue, brown and ground. On the other side are just 2 wires. What happend with ground wire?
On mine it is dizzy end green,brown,, modular end, blue and brown
