FI car need help
rodman
FI car need help
Post by rodman »
My 1980 has been converted to carb setup, Can I remove the FI computer and all its wiring ?
narfire
Re: FI car need help
Post by narfire »
Yes, no issues. Recomend taking your time as there are some that want to go the other way and would need a complete harness. The wires/bundles do fit through the fire wall, believe it is pass side as the computer and relays are located above the pass footwell.
Chris
rodman
Post by rodman »
narfire wrote:Yes, no issues. Recomend taking your time as there are some that want to go the other way and would need a complete harness. The wires/bundles do fit through the fire wall, believe it is pass side as the computer and relays are located above the pass footwell.
Chris
YES I will remove everything encase someone needs it.
SLOSpider
Post by SLOSpider »
Yes remove it and send it to me....Ill pay shipping of course.
1975 124 Spider
1989 Chevy k5 Blazer
1967 GT Mustang Fastback
divace73
Post by divace73 »
I'm always puzzled why someone would remove the FI in the beginning?? Maybe unless to put on twin carbs...
Cheers David
see my >>You tube channel<<
rodman
Post by rodman »
divace73 wrote:I'm always puzzled why someone would remove the FI in the beginning?? Maybe unless to put on twin carbs...
i am guessing the P.O. did it.....
divace73
Post by divace73 »
would you consider converting back to FI? In my opionion it's well worth it, your car will have all the important bits already??
Cheers David
rodman
Post by rodman »
divace73 wrote:would you consider converting back to FI? In my opionion it's well worth it, your car will have all the important bits already??
I would have to change intake,head,get injectors fuel rail, air breather,TPS seems a lot too me..
divace73
Post by divace73 »
You should not have to change the head, the complete system comes up for sale from time to time and usually isn't that expensive, you'll find if someone is selling some FI bit they usually have the whole lot. Maybe worth holding out for a while to see if a system comes out, or put a quick post in the wanted section and see what you get?? My 2c worth ....
Cheers David
