Tach jumps
giuliot60
Your car is a: 81 Fiat Turbo removed Spider
Re: Tach jumps
Post by giuliot60 »
Thanks Dennis, I'll check that.
Giulio/Charlotte
westy64
Re: Tach jumps
Post by westy64 »
bradartigue wrote:This may help you:
http://www.mirafiori.com/faq/content/ta ... achfix.htm
Although in the article John speaks of the Marelliplex the FIAT-Marelli electronic distributor caused the same issue with all types when retrofitted to an earlier, formerly points-type, vehicle.
It seems that PF4684-ND or E4684-ND can't be sourced from the digikey comp.
I will try to contact them for a solution.
westy64
Re: Tach jumps
Post by westy64 »
easier than calling for obsolete part numbers, I typed 0,68µf 400 V on G....E, and got several answers to buy them online.
ordered mine from conrad online shop.
