cable routing
- Your car is a: 1974 124 sport
cable routing
has anyone a diagram/picture of the window regulator cable routing? '74 124 sport 1800. or maybe a link? this haynes manual is virtually useless.
if you can't be an example, be a warning.
- divace73
Re: cable routing
i believe there are only 2 wires?? swap them around if your switch is wrong (or turn switch upside down?)
Cheers David
see my >>You tube channel<<
Re: cable routing
maybe i wasn't clear. this particular car has manual window cranks and the cable i was referring to routes around several "spools" or guides inside the door to facilitate the actual movement of the window within its two vertical tracks.
Re: cable routing
Take the other side doorpanel off and copy its routing.
Re: cable routing
A set of dental pics (that's what I call them ) will come in very handy.
Dennis Modisette
1972 124 Spider
2003 Chevrolet Z71
2007 GMC Yucon
1972 124 Spider
2003 Chevrolet Z71
2007 GMC Yucon
- divace73
Re: cable routing
sorry bout that, should have picked up it was a pre80 eliminated the electric windowrja wrote:maybe i wasn't clear. this particular car has manual window cranks and the cable i was referring to routes around several "spools" or guides inside the door to facilitate the actual movement of the window within its two vertical tracks.
Cheers David
Re: cable routing
That would be the infamous "toilet paper edition".rja wrote:this haynes manual is virtually useless.
Mick.
Re: cable routing
you guys are very informative. and funny, too.
and i'm thanking you very much. heater core is next.
- 81SPIDERMATT
Re: cable routing
MARK SELLS THE METAL TUBES THAT WILL MAKE YOUR LIFE EASIERrja wrote: heater core is next.
Re: cable routing
i'm all for making this easier. got an aftermarket a/c unit hung under the dash right in the way. this should go to another post.81SPIDERMATT wrote:MARK SELLS THE METAL TUBES THAT WILL MAKE YOUR LIFE EASIERrja wrote: heater core is next.
Re: cable routing
update on the window regulator-task completed. w/much white lithium grease applied everywhere it could be; all over the glass included
thanx to everyone again for input and to twincam for expediting the rollers.
Re: cable routing
hey-the tubes have to do w/the heatercore replacement i did after the window regulator replacement, and mark is the site owner, i believe. twincam is a fellow site member that was courteous enough to supply me w/some of the window "rollers" i needed.
Re: cable routing
i need help with my power window. I make a new cable. But, i can't make it right. I see that cable must be wind 3 times on drum. Which cable, this which go on lower rollers or cable that goes to upper rollers. I'm going slightly mad....
7 day I try..oh boy...
How long this cable is suppose to be??
When I buy this Spider driver window did not work. It's a 1979 Spider.
