That is one thought I had. Although it looks as if doing this will only worsen the problem, as I have it mounted so that the bracket is as close to the brake as possible. Perhaps it just is the way it is and it will be fine.So Cal Mark wrote:the arms may not have the bracket in the middle. It looks like you might need to swap the bar end for end if the bracket is offset
Not saying it hasn't been changed, but mine run with the cable over the passenger side bar and under the driver side.blurple124 wrote:That is one thought I had. Although it looks as if doing this will only worsen the problem, as I have it mounted so that the bracket is as close to the brake as possible. Perhaps it just is the way it is and it will be fine.So Cal Mark wrote:the arms may not have the bracket in the middle. It looks like you might need to swap the bar end for end if the bracket is offset
If not, I will post more pictures to help decipher the problem....once my photobucket starts working again. Probably tomorrow morning.
