Slow wipers
SouthwestSpider
Slow wipers
Post by SouthwestSpider »
I've got a 1980 Spider (FI) and I've noticed that my wipers are slow enough to put me to sleep - and that's on the fastest setting. Is this a fixable issue or is it typical of the Spider? Whats' the solution if it is fixable?
Re: Slow wipers
The mechanical linkage under the front cowling gets gunked up and high resistance, and the electrical connnections also typically get crappy and cause a large voltage drop at the motor. Pulling the cowling and cleaning up and lubricating the linkage, while refurbishing the wiring (supply AND grounds) makes a huge difference. Mine are actually useable now! (If I ever drove in the rain of course. <{:^)
Pete
bobplyler
Re: Slow wipers
Post by bobplyler »
Mine was caused by partially stuck linkage. I took it apart, and soaked the big stems in penetrating lube. While moving the linkage around, I could tell immediately when the linkage became free. That helped a lot. The brown wire fix made a little more difference.
1979 Fiat Spider (since new)
1999 Honda Shadow VLX 600
4uall
Re: Slow wipers
Post by 4uall »
aj81spider
Re: Slow wipers
Post by aj81spider »
I cleaned up the linkages (helped a little). cleaned all the connections (helped a little), and found that the wipers were still too slow to be effective.
I added a wiper relay and they work great now.
A.J.
2006 Corvette
SouthwestSpider
Re: Slow wipers
Thanks to all of you - I will follow through with your suggestions this weekend.
SouthwestSpider
Re: Slow wipers
The wipers are working just great! Thanks everyone.
