Many Thanks.....
Since I started the post I have found a couple of youtube videos that might be helpful.
The first is the making of a bubble flare (which is what I think we have) using inexpensive tools...
http://www.youtube.com/watch?v=HVbHk0kkX8k
The second is a video explaining the different types of fittings/flares and their uses
http://www.youtube.com/watch?v=BcUGBdY1 ... re=related
And then last is a standard double flare.
http://www.youtube.com/watch?v=4fmF9mm3 ... re=related
Further research on the Forum gives us the 10mm x 1.25 fittings.
The only remaining piece of information is the actual size of the line or can we use an SAE size line with the metric fitting
OK last piece of the information is that the tubing is 3/16" or 4.75 mm
All of the stuff we need is available here: http://store.fedhillusa.com/britishgirl ... tings.aspx
They have the 10 mm x 1.25 fittings as well.
