81 Ignition replacement
giuliot60
Your car is a: 81 Fiat Turbo removed Spider
Post by giuliot60 »
Has anyone ever replaced their ignition (and key). My Spider's PO added a push button start to mine and I'm not vey thrilled with it.
Any thoughts?
Giulio/Charlotte
rlux4
Re: 81 Ignition replacement
Post by rlux4 »
Just about everyone either has or will replace the ignitions switch at some point. I've done mine and it's pretty easy. The only thing is though, you need the key to get the old one out. I didn't have it and had to drill mine out.
Ron
Ron Luxmore
rlux2n2@gmail.com
vandor
Post by vandor »
Did he do it because the original switch went bad, or just because he wanted to? If the latter, then you may be able to just reconnect the red wire to the #50 terminal on the ignition switch.
If you ever have to take out the switch, remember that to pull it out of the steering column the key has to be in the horizontal position, then put a pin in the hole on the right side and push to release a lock tab. You have to look at it to see what I am talking about.
giuliot60
Post by giuliot60 »
Thanks guys.
I believe he added it because it was bad, Csaba. How can you get a replacement? Is NOS available, or do you have to get one from a parts car?
I'm in no rush, but would eventually like to do it.
Giulio/Charlotte
giuliot60
Post by giuliot60 »
How things change.
After a no-start, after reconnecting my aftermarket wiper, and a link to Mirafiori on how to rebuild the switch from Csaba, I decided to take the plunge. I haven't installed it yet, but the rebuild labor time was about 3-3.5 hrs and I really took my time.
Next step is to remove my push button start and rewire it back to stock.
Wish me luck.
Giulio/Charlotte
sixcharlie
Post by sixcharlie »
Luck is wished. I have an extra ignition. And key. And I'm 20 minutes away.
giuliot60
Post by giuliot60 »
OK. Why didn't I ask you first? :)
Giulio/Charlotte
sixcharlie
giuliot60 wrote:OK. Why didn't I ask you first? :)
Because you knew, that I'd know, that you'd find the answer her, like I did. :-)
giuliot60
Post by giuliot60 »
UPDATE:
After installing the rebuilt ignition, cleaning the fuse contacts and changing the fuses, I had the same electrical/no-start issue that I had before the rebuild.
A bit bummed out, I decided to review the electrical diagnostic manual PDF (Artigue) which led me to check the G3 (ground under the dash by ignition switch). After unscrewing it and screwing it back in, all my electronic components came back on. Relief!
Now that that was resolved, I removed the push button start, reconnected the brown, red, red/black wires, and started the car up with the rebuilt ignition on the first try!
I'm a happy man. :D
Giulio/Charlotte
