Ford Inertia Switch mod for electric fuel pump...
Fiat88
Post by Fiat88 »
Has anyone did this install yet? We had a thread on it once.http://www.fiatspider.com/f08/viewtopic ... g&start=15
I'm just wondering how sensitive this thing will be, don't want the car turning off if I hit a big bump but do want the safety it offers. Can I install it near the dash so I could reset it easily if it does trip? Anyone know? Thanks.
Danq
Re: Ford Inertia Switch mod for electric fuel pump...
Post by Danq »
Hitting bumps wont trip the fuel cut off, there is not enough acceleration. I have had several Fords w/ FI and never had to reset the fuel cut off.
Ron Francis sell a fuel cut off kit
http://www.ronfrancis.com/prodinfo.asp?number=CR%2D92
Dan
1981 spider 2000
Fiat88
Post by Fiat88 »
Thanks for the link! That's cool that a relay is wired up also for the pump. It's a little more the I wanted to spend though but just the inertia switch looks to sell at about $55 at Ford dealer, so maybe not such a bad deal.
I saw some used ones on ebay from reputable sellers for around $15 with the wiring pigtails included. Anyone think I could make my own kit for less then that? What kind of relay would I need?
Fiat88
Post by Fiat88 »
Could I mount it somewhere near the drivers dash so if it trips on a rare occasion I could reset it easier?
donm
Your car is a: 1980 spider [carb]
Post by donm »
I've had my Ford inertia switch for about 5000 miles now and I've never had to reset it, so I wouldn't worry about needing it within reach. I mounted mine in the trunk on the verticle brace right behind the left wheel well, a good solid spot and it's wired in series with the pump, no relay needed.
1979 Spider
2001Saab SW
2004 Saab Aero
htchevyii
Post by htchevyii »
I had a lowered ford Escort when I was young and dumb. I hit a big pot hole one time and tripped the switch. One of my friends ran over a 2x4 on the freeway and their's tripped, so it can happen. The escort's was in the trunk and the exploder's was under the pass side dash.
Trey
Fiat88
Post by Fiat88 »
Ayone try the VW relay method like this post shows? http://www.fiatspider.com/f08/viewtopic ... &sk=t&sd=a
Fiat88
Post by Fiat88 »
Afer doing some research I found that 321 906 059 C relay may not work with CDI ignition systems. My '79 has electronic ignition, is this a CDI system? Seems people who used this relay have the earlier points. Anyone know? Thanks.
