Brown wire fix
courtenay
Re: Brown wire fix
Post by courtenay »
Divers - I don't think it matters if the wire comes from the battery or either the hot terminals on the starter or alternator as those are both fed directly from the battery.
Bruce Shearer
'80 Spider Fi
'10 Volvo XC70
'06 GMC 1 Ton PU
adrians
Your car is a: 1981 Spider Turbo - missing the turbo
Re: Brown wire fix
Post by adrians »
Texasbull wrote:Wait!! Are you saying if I use a BLUE wire that my wheels will stay cleaner????? What if I used a Blue wire with a Red stripe? hehehehe
If you use wire with red stripes - the car will go faster ! :D :D :D :D
THE FLEET
2014 Abarth "SS"
4uall
Re: Brown wire fix
Post by 4uall »
whatever you do NEVER use red wire only..........................red wires are exclusively to be used on Ferrari's
Divers
Re: Brown wire fix
Post by Divers »
Ok...still confused. My 81has the wire at the battery to the starter...BUT...dont I need a second wire from the starter to the key switch?
4uall
Re: Brown wire fix
Post by 4uall »
courtenay wrote:Jay - before you do that, check your battery. My '80 already has the brown wire. I believe this was done at the factory starting in 1980, so our cars don't need this fix.
better photo looks like I can scratch that project off my list :mrgreen:
IMG_0495 by itzebtze, on Flickr
Re: Brown wire fix
Yes, the wire from the starter to the keyswitch is needed to distribute the load over more copper. There was a very very good thread here awhile ago on this subject, in quite some detail, that can probably be found with the search engine. The basic idea is to pull as much load off of the ignition switch as possible, (headlights, wipers, etc) by using relays, and do the "brown" wire fix too.
4uall
Re: Brown wire fix
Post by 4uall »
