Clock bulb: off-the-shelf at Canadian Tire
KidDingo
Your car is a: 1981 Fiat Spider 2000 FI 5-spd
Post by KidDingo »
After a week of scouring the Internet, I have found the answer. You guys & gals will, no doubt, already know this, but I felt I should share lest someone else be condemned to a wasted week of excruciating false leads, dead ends, and lies!
The clock bulb is a 12v 3w Ba9s bulb. It's about 22mm from tip to tip, and 11mm wide. I found a post on this forum that acknowledges Ricambi America (a Ferrari parts supplier) as having the correct part. But at $15 shipping for a $2 part, I wanted to find something locally. Hence, my descent into the heart of darkness that is light bulb manufacturers' websites.
Anyway, The bulb you want, should you seek it, is readily available at Canadian Tire:
Brand: General Electric
Model: T4W
Price: $3.99 for a pack of two
They are longer than the originals, which concerned me since I wasn't sure if they would fit. But they do. AND, apparently they are also used for some of the warning lights and the cigarette lighter illumination.
Ciao for now.
_______________________________________________
Michael
Re: Clock bulb: off-the-shelf at Candian Tire
Now that is convenient!
LGuertin
Post by LGuertin »
I miss Canadian Tire, such nice store, and they even gave you Canadian Tire money.
None of that stuff in california.
4uall
Post by 4uall »
Great post thanks. Go CANADA :mrgreen:
KidDingo
Post by KidDingo »
LGuertin wrote:I miss Canadian Tire, such nice store, and they even gave you Canadian Tire money.
I'll trade you a year in Cali for all my Canadian Tire money! :D
Michael
KidDingo
Post by KidDingo »
For ease of identification:
Replacement bulb:
http://i1106.photobucket.com/albums/h38 ... htbulb.jpg
Replacement bulb packaging label:
http://i1106.photobucket.com/albums/h38 ... kaging.jpg
Michael
LGuertin
Post by LGuertin »
I lived in Edmonton in the 80's, and Fort Mcmurray, Dam cold
I was in Fort McMurray on a day it was -45C in december.
I dont miss those days,
Today in San Jose it is 72F and sunny, nicer weather for a convertible
dantye
Your car is a: all gone
Post by dantye »
I think I need one of these bulbs, eh, so thanks for the part # info!
KidDingo
Post by KidDingo »
LGuertin wrote:I lived in Edmonton in the 80's, and Fort Mcmurray, Dam cold
You're just bragging now! :-)
Michael
124JOE
Re: Clock bulb: off-the-shelf at Canadian Tire
Post by 124JOE »
normaly it below zero F during all of feb in WI
so far this year it has been very mild and above freezing
for instance its 11:48pm and 34 degrees right now
mild
dantye
Post by dantye »
KidDingo wrote:After a week of scouring the Internet, I have found the answer. You guys & gals will, no doubt, already know this, but I felt I should share lest someone else be condemned to a wasted week of excruciating false leads, dead ends, and lies!
Model: T4W
Ciao for now.
This appears to be the same as: http://www.amazon.com/GE-Lighting-Autom ... B001DKV80C
Can anyone who has tried it confirm?
narfire
Post by narfire »
I replaced my burned out clock bulb last week. In BC we have Lordco, jobber store, that has been great for sourcing some parts for the spider, I've bought master cilinders, front crank seals, gasket sets, timing belts, clutch kits, metric nuts and bolts and of course those funny unique bulbs. Lordco will make it to Alberta when they get a wharehouse sorted in northern BC. Untill then you're lucky to have Fred and Mario at Ital Motors in your back yard
Chris
My son is welding up in Fort Mac, Sincrude site, and there was a bit of complaining about the temp, but the paycheques kinda cancel that out.
I've also worked in that kind of temp, and then had a helicopter hovering over head while hooking up logs. Only a couple of hours of that and went back to the motel and drank some common sence.
KidDingo
Post by KidDingo »
[/quote]This appears to be the same as: http://www.amazon.com/GE-Lighting-Autom ... B001DKV80C
Can anyone who has tried it confirm?[/quote]
Yeah - the packaging in the photo at the link you provided is exactly the same as what I found at Canadian Tire.
Michael
dantye
Post by dantye »
KidDingo wrote:This appears to be the same as: http://www.amazon.com/GE-Lighting-Autom ... B001DKV80C ...
I finally got around to changing my clock bulb with one of these from Amazon. (Fortunately it was a burned out bulb, not wiring.) :D A bit fiddly to get at without removing either the clock or Speedo cable, but small, extra-long nose pliers helped.
Although the bulb portion of these replacements is about 1/4" (6mm) deeper than the apparently original burned out bulb, the bayonet base is the same and it fits and works just fine.
doubleclutch
Post by doubleclutch »
There is an article in today's Wall St. Journal about Canadian Tire money. Apparently it has been quite a thing in Canada and we in the U. S. don't know about it. Anyway, it is being phased out, so, LGuertin, it's just as well that you have moved out of Canada to balmy California.
