Key in ignition warning buzzer
My key warning buzzer (1978) makes and awful noise so I would like to disconnect it. Either wire removed BW or Brn kills the buzzer. Will removing either of the wires affect any other component or circuit? psg
- 124JOE
Re: Key in ignition warning buzzer
can you put in the key and locate the buzzer
then unplug it
then unplug it
Yeah, I have already disconnected the buzzer but I am wondering if the fix for the noise will create a problem in some other circuit.
Everything seems to continue to work just wondering if there will be another problem before I put everything back in place.
Anyone ever put in a replacement bell off another car or from Radio Shack? psg
- Your car is a: 1976 spider
Mine is under the glove compartment box (has to be removed to access it). It was disconnected with no ill effects.
76 Spider
St. Louis, MO
St. Louis, MO
I have my stereo wired into the buzzer power wire so it comes on when
the key is in the ignition. Works great.
Dennis Modisette
1972 124 Spider
2003 Chevrolet Z71
2007 GMC Yucon
1972 124 Spider
2003 Chevrolet Z71
2007 GMC Yucon
A quick look at the wiring tells me that there is nothing else on that circuit. It's just power (+12v) coming from the ignition switch and ground. Shouldn't cause any problems.
Merry Christmas!
Joel
Merry Christmas!
Joel
