My cable has a kink in it that causes the speedometer to jump. No local shops could get me a replacement, so I ordered one from IAP. The length is correct, but the female end that screws into the transmission istoo small. Has anyone else had this problem?
Has anyone tried taking the end off the cable and swapping it out. I may try since I don't know what other options I have.
Thanks.
Russell
1972 Fiat 124 Spider
1972 Replacement Speedometer Cable Problem
- Your car is a: 1972 124 BS1 Spider
Russell Randolph
1972 124 BS1 Spider
1972 124 BS1 Spider
- 124ADDHE
Re: 1972 Replacement Speedometer Cable Problem
Call up IAP, maybe they sent the wrong one? Thats shitty!
Regards,
Keith Cox
1973 124 Spider
1973 John Deere 500c backhoe
1987 Jaguar VDP
2013 passat tdi
2015 cherokee
Keith Cox
1973 124 Spider
1987 Jaguar VDP
2013 passat tdi
2015 cherokee
I now noticed it doesn't fit at the speedometer, either. They put the rubber gasket for going through the floor on backwards. It I flip the cable around it works on both ends. I will call IAP on Monday.
Russell Randolph
1972 124 BS1 Spider
1972 124 BS1 Spider
Why does it matter which way the rubber bellows that seals the hole in the floor goes?pdxfiat wrote: They put the rubber gasket for going through the floor on backwards.
I wasn't crazy about having a cavity for things to fall into, but thought I would just do that if IAP didn't have a solution. I called today and was told that occasionally that happens. He grabbed a few from the the warehouse, they were backwards, too. So he said he would call me back. About half an hour later, he calls back saying every cable they had was backwards. Then tells me that him and this other guy managed to use multiple hands and screwdrivers to lift the boot off and turn it around. I said my wife and I would do that on the one we had. He said don't bother, he is sending out the one they flippedvandor wrote:Why does it matter which way the rubber bellows that seals the hole in the floor goes?
for no charge and not having me return the one I already had.
The cable was just one item in a bigger order, but I'm impressed with IAP's customer service!
Russell Randolph
1972 124 BS1 Spider
1972 124 BS1 Spider
